I have just finished installing a twelve volt conversion and apparently I've had a brain fart or a blond moment or both. Getting zero spark at plug. Also only reading 6 volts at the coil with ignition on. I purchased the kit from this YT. I installed as instructions stated.
Yes, a new 12v coil was installed. As well as new plugs, wires, points, cap, rotor and condenser. I used the "wiring kit" that was included.
Motor will spin fine and I have rechecked wiring. I'm no rocket scientist, but usually pretty darn good with motors.
Any suggestions, other than firing my mechanic......... Thanks for the help.
1951 8N Side Mount Distributor
