1948 right brake hangs up and drags when the pedal is depressed. Back up a foot and you can go forward without the drag till you use that pedal again. FO 4 manual says that two retracting springs are used on the left and only one on the right. Why are two springs needed on the left? Mine has always had just one on each side and both worked fine till a short time ago. Brake shoes are not very old, properly adjusted and show some shiny spots in the right drum but not any shiny marks in the left drum. I seem to remember reading about a similar problem on this forum some time ago, but am unable to access the search part. Retracting springs on both sides are in good shape and appear to be hooked in the right places. Any suggestions as to what"s wrong?
Thanks, Tom/Idaho
Thanks, Tom/Idaho
