9n front axle bearing replacement issue
SDE
I changed the bearings and then, when I put the cap on, it would not screw on all the way. I removed the hub from the axle and tried to put the cap on again and again it would not thread all the way on. I put a large chamfer on the inside of the cap and it will now thread all the way on. It was making contact with the bearing cage. I will need to do it to the other side also. Is this a common problem or am I just a lucky guy?
Thank you
SDE
