Need Right Hand Hitch Adjust info
Bobcatter
New User
Brought home a 1949 8N. Having fun going over everything. I thought the crank handle was froze up, but when I disconnected it, the handle worked just fine. Thanks for any info, I did try searching but didn't get anywhere.
Here's my question: If I turn the tube with the vice grips on it, will threads unscrew from the part it goes into? Is it normal direction threads? When it functions normally on the tractor, when I crank the handle, I should see threads as it lengthens, right?
Looks like it has dried up grease in it, so I'm hoping it is just frozen at the top. But before I start cranking on it, I wanted to make sure I understood how it worked.
Picture went sideways on me.......
[/img]
Yes, the lower portion will screw off.
I think it was standard right hand thread but if not it will be
easy to tell once you start turning it. You will see the threads.
The dried up grease in the gear box may be the only issue.
I've gotten lucky with that in the past.
All I had to do was take it apart, clean it and re-grease.
Thanks for the quick reply. I will give it a go first thing in the morning. I may need some heat, so far it really didn't want to move! It's soaking with some penetrating fluid. I did see access to the threads from underneath, so it all looks good. Overall the tractor doesn't look to be beat- so far so good!
put some penetrant down in the threads . then use some heat.. and maybee a pipe wrench.
if the threads go bad.. some people weld the rod in the yoke and the weld bead is hard to see.
I have fixed them by welding a big nut to the yoke and welding new threads onto the shaft either by transplant or weld and re-
thread.
