NAA main harness routing
Hello,
I'm replacing the wire harness on my NAA. The current harness is old and a spliced together jumble.
Does anyone have any pics of the path the harness takes from the VR to the gen? I'm mainly concerned about where it routes, the path it takes, near the battery tray, air cleaner, starter solenoid area.
Thanks again!
Muskie
if you buy a pre made one, it pretty much only goes one way, and most of the harness is up at the dash anyway.
if you are making it yourself, route it however you wish.
It's pre made.
Im not there to look at the tractor now, but there are several paths the harness can take where it drops down near the batt tray/air cleaner. I'd like to see how others are routed there.
Also, I'd like to see where others are crossing over w/the coil wire. I haven't hooked mine up yet, but holding up the harness, it looks like the coil wire is going to cross right by the steering linkage/tension plate, which doesn't seem ideal because of the moving parts.
So, does anyone hane pics of the wire harness routing on the NAA???
Thanks,
Muskie
open your yt safe mail address & I will send what I have, or use my open link in Modern View to e-mail me.
Thanks for that link, JMOR. Those pics did help help somewhat.
I'm certain I'll refer back to those pics for other NAA stuff. He has a large collection of pics, that's for sure!
He wasn't playing games with that restoration.... Taking everything down to metal... bright and shiney.
It's nice to see an NAA "exploded" like that.
Again, thanks for the help! It's appreciated.
Muskie
