Possum235
New User
How do you check if solenoid is bad on 8n i cleaned
all the connections and have good battery the
solenoid clicks the will finally start but getting
worse
You might want to consider replacing the solenoid. Most part houses stock. You can use an OHM meter to check to see if there is any "resistance" between the posts.
My best advice would be to spend the ten bucks and replace the worn one. There usually is no in between with a solenoid. It works or it doesn't. Make sure to disconnect battery, unless you want some excitement. Good luck.
when u say u cleaned all the connections - does that include the battery ground as well (both ends) ?
" and have good battery "
How do you know that?
Unless you are using a hydrometer or load testing it (see tip # 49) you can't be sure the battery is good.
75 Tips
