Replacing ring gear on flywheel, what else while in there?
kev518n
My 8n tractors ring gear is bad and ruining starter drives. So i got one ordered and am going to split the tractor and replace it. Of course while in there im going to replace the clutch,pressure plate and throw out bearing. Anything else a guy should replace while in there? Thanks in advance
See tip # 59 before you put it back
together.
Also replace the pilot bearing and
transmission seal.
Use the main shaft as the clutch alignment
tool. And don't put the disc in backwards.
75 Tips
You might check the condition of the pilot bearing (as well as replacing it) if it is frozen (like mine was) the input mainshaft might be worn excessively where it pilots in the bearing. It is not that difficult to replace.
A couple 9N7086 gaskets, depending on how you split it you may need a couple 9N9652 hoses. About all I have ever done needed a new screw kit for the Air Cleaner Funnel To Hood
32940Kit Years:1948-52 Air Cleaner Funnel To Hood Screw & Nut
9N7086 Years:1939-54 Gasket (Main Shaft Bearing Retainer)
