I recently purchased a 1950 8N, and have a question about the hydraulics. There are 2 taps in the case, 1 on the top of diff and other under the seat. There is a hose connected from the test port to the tap under the seat. I believe this modification was done to add a remote cylinder and not have to chain the lift down?
I need to re-route the hose because the Low range lever hits the hose (was a nice surprise to find out it had the Howard low range). I have a couple of questions: What would happen if I engaged the PTO with this hose disconnected, will it build pressure and something blow, or is there an internal pressure relief? Is the fitting on the diff also a return the test port hose could be connected to? Thanks
