I tried searching around this forum and could not find this exact information. The machine shop is about to bore my block (originally had 040 sleeves) for the 090 sleeves. Seems that .001 min to .003 max press fit is recommended. Also makes sense that there should be no interference fit for the top sleeve ring (lip) OD. My main question though is how deep should the top step be ? Seems like it should be deeper than the lip thickness, and then the sleeve is installed flush with the block, but by how much ? I broke the lip on a couple of the 040 sleeves when I installed them so I want to make sure I get it right with the 090 sleeves. On all other sleeve installations, the machine shop has put a step in the bottom of the block bore (about half the sleeve thickness) and then decked the block flat so sleeves and block are flush. This is their first 8N though.
