luv2wrench
I need to replace my push/pull type ignition switch on my early 8N (serial 190). Does Napa offer a decent style or is there a better one out there? Is a Key the way to go? Tractor shuts off time to time. Has no spark until you do the ole tap test on the switch and then it fires right up. Tractor has a 8 volt battery in it and a SI10 alternator on it. seems to work fine??? I just replaced points (.015"), condenser, coil, dist. cap & rotor, copper wires, Autolites 437 (.025"), new fuel filter screen in bowl, carb gets plenty of fuel and tractor purrs like a kitty while running.
Thanks experts.
luv2wrench, ret.
Thanks experts.
luv2wrench, ret.
