This message is a reply to an archived post by OzinKS on April 15, 2012 at 17:14:00.
The original subject was "8N stalls after 1530 sec running".
I have a 1954 NAA. 12 volt. Sat for three years. Cleaned the gas tank, changed the plugs an wires, new coil, rebuilt distributor, cleaned the air filter, cleaned the breathers, checked the compression (110 on all 4), new ignition, ( I may have missed something on that list ).
My tractor runs for maybe 15 seconds, then dies unless choked. If throttle is set at lowest idle, it sometimes runs an runs an runs, until throttle is given. It starts up right after, runs for 10 seconds an just struggles to run an dies, unless choked, ( choking it let's it run an additional 5-20 seconds). I've changed everything I can think of. I need some advice. Oh an I changed the fuel line if I hadn't mentioned above.
