rened zuniga
Just converted my NAA from propane to gasoline. Installed gas tank, new fuel line, points, condenser, and carburetor (rebuilt). Got everything working; tractor starts right away. However, once I start giving it gas, when I have pulled the throttle about 3/4 of the way, it suddenly dies on me, OR when I try to run it in 3rd or 4th gear. Then it will not start again at all. I have choked it, but nothing. I have used starting fluid, and again nothing.
However, if I let it sit all day long, or over night, it will kick on right way, no choke or starting fluid. Will start as soon as I press the starter button and will run on idle until I give it some gas or try to run in three or fourth gear, then it dies.
Question: Since I converted the tractor from propane to gasoline, Do I need to chance any ignition or engine setting??????
Thank you in advance for your assistance. David
Question
Question
