Hiya,
I think I have most of the parts to re-configure a Steel-wheeled 1942 2N tractor. I have the magneto and drive, a full set of steel wheels, the starter motor block off plate and the starter button delete plug along with the idler wheel tensioner for the fan belt (because there is no generator to tighten the belt). I am guessing there was probably a block-off plate where the starter solenoid mounted under the battery tray(??)
Is there anything else that was originally part of this stripped down, war rationed tractor? Also, does anyone know where there are any detailed pictures of the steel wheeled 2N on the web?
Thank You,WB
Thank You,WB
