12.4 x 28 R4 tires?
Are r4 12.4 x 28's available? I'd like to try a set on my 8n. I was thinking they might give me some more traction in reverse than the r1's I have on it now.
The ground out here is blow sand. With my drag type shredder, backing up can suck because of the lack of counter weight on the three point. It's not bad with the box blade on.
The basket case 8n that I'm fixing to start on will need tires anyways.
R4 tires are not traction tires, forward or reverse. R1 tires are better for traction in either direction.
Ad ballast if you have traction issues in either direction.
Dean
Several folks I have spoken with in regards to the r4 vs r1 debate swear by the r4s in the sand.
It's literally like driving on a beach out here. On the beach in a truck an all terrain or street tire works much better than a mud tire. Seems like the same concept would apply here. No?
The R1's are great going forward but suck in reverse, even with ballast.
