JeffG in WI
I have a 1954 NAA with newly rebuilt engine, and thanks to the help I got on this forum, it is running great. But....
While I had it taken apart, I figured I'd split it and try to fix the nagging grinding/rattling noise in the middle to back half of the tractor. The noise was always present, EXCEPT when I pushed down on the clutch pedal. Louder when in gear than when out of gear, but still always there if the clutch pedal wasn't pressed.
I changed the clutch assembly, pilot bearing, throwout bearing, and bearing at the rear end of the input shaft. Figured it would be fixed. But now that the tractor is running again, the noise is still there!
Any ideas?
Thanks!
Jeff
Any ideas?
Thanks!
Jeff
