Kid Shileen
Hi all. New to the forum and the wonderful world of the ford 8n.I just replaced my starter solinoid. Prior to replacement there was nothing when the starter switch was pushed. After insalling the new solinoid I went to connect the battery cables and the starter engaged and would not stop until i disconnected the negative cable tried it again with the key on and the tractor did start but the starter was still engaged.
The tractor is a front distributor. Electrical is a 1 wire 12 volt alternator and 12 volt battery. Any ideas? Thanks in advance for any suggestions.
