Starter engages when battery cables connected
Hi all. New to the forum and the wonderful world of the ford 8n.I just replaced my starter solinoid. Prior to replacement there was nothing when the starter switch was pushed. After insalling the new solinoid I went to connect the battery cables and the starter engaged and would not stop until i disconnected the negative cable tried it again with the key on and the tractor did start but the starter was still engaged.
The tractor is a front distributor. Electrical is a 1 wire 12 volt alternator and 12 volt battery. Any ideas? Thanks in advance for any suggestions.
If you have correct solenoid and IF you installed it correctly, it may just be stuck closed. Whack it a good rap....most often, they will release.
How could it be installed incorectly. I will not be offended by being corrected.we all make mistakes. What should I check to make sure it was hooked up correctly?
How could it be installed incorrectly? It's
easy to install them backwards. And the
results are exactly as you described. Is the
little terminal for the starter switch
facing out or towards the block?
It's also very easy to get the wrong
solenoid.
75 Tips
Solenoids are not made the same. It has to be for a tractor. If the parts guy gave you one for automotive apps. It won't work.
If you connected the cables,wires to the wrong terminals it won't work. Post a photo of the solenoid.
[i:cd573180d9]there are teardrops in her heart
but they can't make her cry
she's lost all the kin that she's known
and the tears will turn into stone
all the teardrops in her heart
'cause they can't make her cry
it's not very hard to weep
when you're a little girl
but they made a little girl feel
like a woman made of steel
makes no difference how they try
they'll never make her cry[/i:cd573180d9]
welcome to YT, kid :)
The new solinoid is identical to the old one. I have the small post pointing toward the engine. The boz
that the part came in says 8n 1948-1952.
(quoted from post at 19:11:07 08/19/16) Many thanks jmor. Goes to show that there is very little that can't be fixed with a little metallic
persuasion.
ou are welcome. If at first you don't succeed, get a bigger hammer! :wink:
(quoted from post at 16:45:17 08/19/16)
persuasion.
So...what's to keep it from sticking again? Not being a smarta$$. Just wondering, if they are bad will they keep doing it?
(quoted from post at 11:05:06 08/20/16)
persuasion.
aybe, maybe not. Too high a current, resulting from a bad cable/connection/battery or starter can make one stick & once that/those problems are fixed, I have had them never stick again for decades.
