i have 8n Rod Bearings, Main Bearing
8n tractor
New User
have Rod Bearings, Main Bearing out of 8n motor
Main Bearing has number MS120P-000
Rod Bearings number are CB200P-000 are these stander bearings
(quoted from post at 22:54:50 08/15/16) have Rod Bearings, Main Bearing out of 8n motor
That is the part number for Clevite/Mahle Tri-Metal 77 bearings in standard size.
TOH
(quoted from post at 07:02:42 08/17/16) Usually undersize bearings are stamped on the backing with the amount of undersize.
I believe that would be the -000 portion of those Clevite/Mahle part numbers:
MS120P-000 = standard size
MS120P-002 = .002 undersize
MS120P-010 = .010 undersize
and so on....
TOH
