8N sleeve best install tips
joe in WI
Hello, I have a '47 8N that needs sleeves. what is the best method to get the new ones in? it has the .090 sleeves. any sneaky tips? thanks in advance
i put mine in my chest freezer overnight (0 degrees F) and they dropped in with no fuss. but there's another thread from someone who wasn't so lucky...
On a Farmall M I had good luck with the chest freezer. I put a heat lamp from my brooder house in each empty cylinder for a couple of hours. I had to do two taps with a wood block to seat them all of the way. Take them out of the freezer one at a time and put them right in.
Joe,Notjustair's way has always worked foe me is the same way that I have installed dry sleeves for years with great results. Check the fit at room temperature first,all to tight then I use a ball hone just to clean up the walls,freeze the sleeves and put a heat lamp on the block.Once hot I oil the bores good with oil and shop towel,then put the sleeves in one at a time.
(quoted from post at 22:02:07 08/14/16) Hello, I have a '47 8N that needs sleeves. what is the best method to get the new ones in? it has the .090 sleeves. any sneaky tips? thanks in advance
If the fit of the sleeve to block bore is correct (.0005"/.0015" interference) the .090 wall sleeves can be carefully driven or pressed in with little to no fuss. The .040 wall sleeves are a different animal.
TOH
Thanks all for the refresher. it's been years since I have installed sleeves. I had forgotten about heating the bore prior to putting in the sleeve. the last sleeve I put in was in a race engine in '76, and we used dry ice to freeze the sleeve. I had forgotten that we warmed the block. thank you again!
I do some work on KOHLER engines that have sleeved engines. I took an old Coleman ice chest and use dry ice to make the sleeves really cold. Liq. CO2.
I got in a lot of mom's type of trouble when I was just a lad. I would forget (anxious, I guess) to replace some of the homemade food back into the freezer.
So, that night's supper was turkey., instead of our daily MUSH (fried). :)
John,PA
