Cold compression test
Chuck123
New User
I have not yet gotten this 1950 8n started. It has been sitting for 15 years. I put a little oil in each cylinder a few days ago just to lube the rings. With all the spark plugs out, I checked the compression. It came out as follows. 50/35/45/30 I this normal for a cold engine ? It seems low to me. Does it give me any useful information ?
If you can safely do it, with the aid of a helper, try to pull-start it. If you can get it started, run it/work it, then appraise it's condition by repeating the compression test.
(quoted from post at 15:02:16 08/14/16) If you can safely do it, with the aid of a helper, try to pull-start it. If you can get it started, run it/work it, then appraise it's condition by repeating the compression test.
ditto
"Will the scrap yard take 8ns"
most will - but at today's prices, u won't get much.
Did you happen to have the throttle wide open? That will make a difference.And how fast was the engine turning over?
With numbers that low it won't matter... I would use 2nd its gonna take a good spin to fire it up if it will fire off... I have pulled 2 vehicles off with success that would not start in my life time. One was a IHC truck and the other a JD 1010. The truck would start and run good after the pull I never did know why I had to pull it to get it running. The JD would not start on its own after the pull it ended up the valves were to tight. I have never had to pull start another non runner I knew were the compression loss was and went after it and fixed it.
Google cylinder leakage test.
The old yard ornament fired up today. It smoked for about 15 minutes then settled down. I ran it for about 35 or 45
minutes. It will start right back up now. Seams to rev a little slow. When I compression test it what is the
sequence ?
Minimum acceptable pressure is 90 lbs w/ the lowest pressure reading w/in 75% of the highest reading. Run the engine to operating temp, turn it off, remove all 4 plugs, remove the breather hose & make sure the choke and throttle are both open. Start w/ # 1, closest to the radiator. Crank it at least 5 compression strokes or until the gauge stops moving. Write down the first compression reading (that is the valves seating) then write down the reading after 5 strokes or when it stops increasing. You should have two numbers for each cylinder. Then, add a tablespoon of oil to each cylinder & repeat the process, but you only need the final reading for each cylinder. Write down the results & post back for help figuring out what it all means.
75 Tips
