8n rear axle nut
rray
The left rear axle nut on this 49 8N had no lock ring and was barely hand tight. The threads on the axle are serviceable but not great. I am considering getting one of the two piece locking nuts. Has anyone here used this?
I had to use one on one of my 8Ns. I didn't have any trouble.
I put the nut portion on, then started the lock portion on but
didn't tighten the lock, just snugged it up to hold the threads.
I tightened both as a unit, then tightened the lock down to hold.
I just got the 2 piece nut.
I usually put antisieze on just about everything.
Should I put it on the tapered axle spline?
