Exhaust Manifold Gasket Installation Question
chasbar431
New User
I am replacing the exhaust manifold on my 1952 8N and am ready to put the gaskets on. Do I need to put a gasket sealer material such as Permatex Ultra Copper max temp gasket maker on the gaskets or not? It is a new aftermarket manifold from YT and I have used ThermoSteel on the block to smooth out any pitting. And if I do need the gasket maker material, do I apply it to both sides of the gaskets? Thanks for your help.
i replaced my manifold a couple of years ago, and used no sealant. so far, so good.
I replaced my 48 8n manifold last month and gooped both sides
also re torqued after some use time (when cooled)
no leaks or regerts ... 8)
Use the hi-temp Permatex on both sides of the gasket. You've got intake ports there as well. And don't forget to re-torque it after it cools; start on the inside nuts & work out.
75 Tips
I've done it both ways with success but I normally use high
temp sealant on both sides as was mentioned.
Just don't get carried away with it. You don't need a 1/4 inch
bead of it. All you really need is a smear coating on each side.
I replied on tractor talk, it goes to show you how much pizz poor advice folks put on the net and proud of it... Goferit...
"it goes to show you how much pizz poor advice folks put on the net and proud of it"
is that a shot at me, hobo?
