Oil check value
Possum235
New User
Changed oil today cleaning oil lines just under the oil canister I took the fitting off it looked like it had a small round check valve any way I lost it can I still run tractor without it
(quoted from post at 11:30:43 08/10/16) Changed oil today cleaning oil lines just under the oil canister I took the fitting off it looked like it had a small round check valve any way I lost it can I still run tractor without it
here are hundreds of tractor models. What is yours?
In reference to the parts catalog drawing below where did you find the "check valve"?
<img src = "http://cnh-b2b.ptcmanaged.com/index.php/sbsimage/NH/default/191805.png">
(quoted from post at 14:12:57 08/10/16) Drain plug not shown on the diagram above???
Drain plug was on early Ns &amp; was stopped pretty early in the series.
"Drain plug was on early Ns &amp; was stopped pretty early in the series."
interesting. mine has a drain plug, and we've decided it's not the right one for a 47 2N. so that sounds like it must be from an earlier model, up till now i'd been thinking later.
(quoted from post at 14:59:48 08/10/16)
bout 8 years ago, Bruce VA said they didn't stop the drain until SN 269,530. Later than I thought. :oops:
I thought it was below oil canister #16 in throttling now I'm not sure it was a round type valve or possibly a oil bubble eyes not as good as they use to be
My early 8N has a drain. Here is a picture from a 1949 Parts manual showing the drain plug but no check valve.
Gary (OR)
