b:42c076cd0e][i:42c076cd0e](quoted from post at 22:26:32 08/02/16) Possible, but could be water pump. A stethoscope could help locate it.
(quoted from post at 22:00:21 08/02/16)b:c0d1c9a666][i:c0d1c9a666](quoted from post at 22:26:32 08/02/16) Possible, but could be water pump. A stethoscope could help locate it.
I'm with you HC..........sounds to me like a waterpump knock (fixen to fall apart) ????
Gary :?: [/i:c0d1c9a666][/b:c0d1c9a666]
b:1a01e5097b][i:1a01e5097b](quoted from post at 23:18:10 08/02/16)(quoted from post at 22:00:21 08/02/16)b:1a01e5097b][i:1a01e5097b](quoted from post at 22:26:32 08/02/16) Possible, but could be water pump. A stethoscope could help locate it.
Gary :?: [/i:1a01e5097b][/b:1a01e5097b]
I do believe you can see it jumping right along with the noise.
(quoted from post at 05:32:47 08/03/16) Thanks everyone, I did remove the belt and the noise remained, wouldn't that rule out the waterpump?
(quoted from post at 08:00:30 08/03/16) teddy would that have required the head off recently? It hasn't been off in at least 8 years.
(quoted from post at 17:12:07 08/03/16) It means you can get to them with a link, but they're not found
in a general search of YouTube as a "Public" video would be.
Not quite the same as "Unrated" thank goodness!
