I am rebuilding the carb on my 2n. I bought the cheaper kit at TSC. I have taken it apart and cleaned the carb in my small HF ultrasonic cleaner. However, I have flash rust inside and outside of it. Will this pose a problem or should I go ahead and assemble it? If I need to remove it, what is the best way?
My kit does not come with jets or a power needle. Is it ok/advisable to reuse these components?
One last thing, my kit did come with a new throttle and choke seal. Does the brass insert pressed into the carb body have to come out before replacing this seal? Or, does the seal fit on the outside of this brass fitting?
I appreciate your help!
