steve19438
does adding water pump lube do any good or is it so much snake oil?
thanks.
thanks.
(quoted from post at 07:48:18 06/07/16) does adding water pump lube do any good or is it so much snake oil?
thanks.
(quoted from post at 08:10:11 06/07/16) beats me I simply asked a question.
(quoted from post at 06:48:18 06/07/16) does adding water pump lube do any good or is it so much snake oil?
thanks.
(quoted from post at 08:02:29 06/07/16) While you're at it, you might as well tune up the car a bit...
Syntheic blinker fluid
(quoted from post at 08:43:27 06/07/16) Any decent permanent anti-freeze contains water pump lubricating additives.
If you change the anti-freeze every couple of years there is no need for any other coolant additives in your N.
Dean
nhibit rust to keep surfaces smooth.(quoted from post at 12:33:18 06/07/16) My understanding is you are not lubricating bearing you are increasing the ability of to coolant to pass through the pump fins/vanes to reduce wear on the pump fins/vanes or housing.
(quoted from post at 14:05:23 06/07/16) You can add sca back in, this is what makes the protective barrier that inhibits corrosion, this is common in diesel engines to replenish them. Antifreeze never goes bad it only becomes contaminated or breaks down the sca package. When at a seminar once on diesels and antifreeze maintenance the instructor had mentioned how it never goes bad and I asked about what needs replenishing in gas engine antifreeze then and he said that just a small doses of the additive we use in the diesels would bring back that in very old antifreeze as long as it's not contaminated of course
(quoted from post at 09:19:20 06/08/16) Good info TOH, I was under the
impression that the sca package of
additives helps bring the ph back to
where it should be since our test strips
generally reflected that result?
(quoted from post at 09:07:02 06/08/16) I would not run 100% water with out water pump lube.
Permanent anti freeze I figure has it built in.
We used Mac's 13, 50-65 years ago in water only vehicles.
