I do have less than 1/4 of our property that I intend to work that has some real uneven and sloped terrain. Is there any reason I couldnt just swap the rear set around, for proper tire direction, and widen the front out? I ask because I read a discussion recently where someone wrote about "if not done properly it is bad on bearings." I was of the thought that if it was possible to swap to the widest setting that it was built for that internally as well.
I do value the opinions here. I also know that the wider setting will be much more stable when using the loader for the next few months with clearing chores in that area.
Thanks all!
Thanks all!
