Re: Something other then a sediment bowl
DGinVT
07-20-2016 05:35:35
You might try using a piece of fine emery paper fitted on the end of a dowel that will just fit the inside area where the gas fits and polish the face. I currently use a slightly thicker cork gasket using a gasket cutter in my drill press or else a soft rubber. The screen goes in first and then the gasket and then the bowl. On my 8N Ford I to use a tiny amount of gasket shellac and it worked fine. Some of those seal well others need help. Also check the glass bowl and make sure the sealing face is perfectly flat.
