I have no idea where you could get a new one, but these guys should be able to help you w/ a used one:
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
Rod forest lake tractor 651 464 4628
75 Tips
Boler76,I believe there are some new cams available for the side mount #8N6250.But I don't know of any NEW cams available for the front mount # 2NC6250B.Looks like you will have to find a good used one or even have one reground.Maybe someone on here has one they are willing to sell you.
Here is one
well how would I know that a used one would be better than the one I already have is the question? I have no experience with reground camshafts, Am I right in thinking that there are no camshaft bushings(bearings)? If so what happens when the cam is reground?? Thanks for all and any info.
You can tell if its good by measuring it. And the N's do not have cam bearings. A reground cam has been restored to factory specs as to lift, etc.
