trying2mow
When I throttle back, even with the little set screw on the throttle bar not even touching, the
motor is 3/4 speed. I can't get it to slow down . I screw in the screw to the front of carb and
it will slow engine down but then I can't get engine to respond to throttle lever. That is..I
can't get the motor to speed up. The choke has to run with about 1/2 in out.???Either I am almost
wide open or I have no response to throttle lever. Please help ..anyone. Thanx
PS Did I say it has no lever throttle response to engine speeding up or slowing down when I adj
that front screw to get the engine speed up?
