Vertical Air Cleaner
mwjohnson90
New User
I have a 1950 8N that was equipped with several 2N parts. I know 8N's normally don't have the air cleaner thru the top of the hood but we are trying to restore it to the way my grandfather had it. Only problem is I can't seem to find one of those air cleaners. I was hoping somebody on here might be able to point me in the right direction. Does anyone know where i could find this type of air cleaner?
You're right, 8N's had an air intake on the side of the hood.
9N/2N had an optional through-the-hood intake as I understand.
Not original to them either. They were all under the hood.
All that to ask, are you looking for new or used?
I might have a used one out here, I'll need to verify.
If not, John Smith probably does.
YT sells the oil bath canister new as do others.
I didn't look for the through-the-hood extension.
[b:29198c9aa8][i:29198c9aa8]
I see that Royse has a couple of answers as to the oil bath can,
Just thought I would post this in hopes it may help.
Pay special atten. to paragraph # 5 &6, for how to attach. the 'through the hood pipe'
I am assuming the pipe hole is still in your hood......If not, the instructions for installing the hole is here on this instruction!!!
Hope this helps??!!
Gary
[/i:29198c9aa8][/b:29198c9aa8]
A used one would work just fine if I could find one. I'm not sure who John Smith is. I have seen many people mention him in
different discussions but I'm new to the forums.
I'll see what I have when I get home from work today.
John is a forum member here who has a lot of Ford
tractor experience. Not to mention being a great guy.
Here's his website.
The tractor ID/History section is second to none.
He also has used parts listed. If you don't see what
you're looking for contact him. He may have it.
Thank you very much for looking and thank you very much for the reference to John's website. I will have to sit down and read the
id/history section when I get a chance.
I went out and looked this afternoon, I do not have any
left with the vertical extension except the one on my 9N.
I don't really want to part with that one.
I do have a couple that are under hood if John doesn't
have one. At least that way you'd have one to convert.
I don't blame you there. I would not want to part with it either.
As for the under the hood one I appreciate the offer but that's
alright. I'd really like to keep the tractor the way it was. Thank
you for checking if you had one and for all of the help.
