Carb problem or what?
jim wieringa
New User
i have a 9N that has always needed the choke pulled out to run smooth. Tired of it. I bought a new carb and it still acts the same. It has a
leak from the exhaust gasket which is on order and will be replaced this week (hopefully). Is there anything else I should be looking for.
Thanks JW
Pulling out the choke gives you a richer mixture. So, you could have either a fuel or spark problem.
A carb out of adjustment will also cause this problem; set the main jet at 1-1/2 turns out & leave it alone.
A dirty carb can cause the problem as well; start by cleaning the fuel screens.
Dirty/old gas, or water in the gas can cause this problem.
Restricted fuel flow can cause this problem; remove the bolt at the bottom of the carb & check for flow.
On my 1950 frontmount, needing choke to run is the first sign that the points need adjusting/replacing.
A vacuum leak can do the same thing. Get a hand propane torch and carefully spray it (unlit of course) around the intake manifold at the carb to manifold interface & the manifold to block gasket of the tractor while it is running. Or, you can use carb cleaner or WD40. If it speeds up, you found the leak. Sometimes (rarely) manifolds crack or get rust holes.
Lastly, when all else fails, you could have an air leak around the carb metering section. The likely suspects are leaky throttle shaft seals and/or a worn throttle shaft. Or, just a real dirty carb w/ clogged passages. But, a new carb shouldn't have this problem.
Bottom line: Probably 90% of "needs choke to run" problems are fuel related, but do not rule out ignition problems, contrary to what others may tell you. I?ve had that very same problem before w/ a rebuilt carb, fresh fuel & good flow & a tight manifold.......and it was a spark problem. But, that was unusual. Just check the likely fuel problems first.
Please be sure to post back & let us know what the fix was. We all learn something if you tell us what worked!
75 Tips
Bruce has you covered here.
The only thing I might add is the overly obvious question
of whether you tried to adjust the new carburetor.
They need to be adjusted to your machine.
If you did then I would run with what Bruce has suggested.
When checking fuel flow out of the plug on the bottom, let
it run for a couple of minutes. It should run steady, not slow
down. It should fill a pint jar in about two minutes or so.
