Ignitor ei on early 8n
Yes it worked great no iffy about it other than if you want to nail the timing you got your work cut out fer'ya...
Your issue is a front mount P.O.S. distributor that's not friendly to anything... You have to be a dedicated guy to make improvements to it.
(quoted from post at 20:04:09 06/25/16)
(quoted from post at 10:06:20 06/25/16) Has anyone had experience with Ignitor ei on front dist early 8n?
I've converted 2 front mounts to EI. What do you want to know?
Rick
here is a single wire coming from the EI. Does it attach to the coil?
(quoted from post at 09:31:35 06/26/16)
Rick
F the EI module has only one wire, I would say that it is trash.
(quoted from post at 21:31:28 06/26/16) Went to that site and found the diagram I needed. Thanks for the info
ith only one wire, it must be a really simple diagram?
(quoted from post at 05:52:50 06/27/16)
ound out on Petronix site that single wire attaches to the contact on the coil. thanks for all of the responses.
