KCTractors
- Location
- Central Wi
I am wanting to adjust the valves on a 8N. I broke every set of valve adjusting tools I had ( 4 sets) and haven't got the job done yet.
If I drill holes into the block where the lifter are, I can probably put a magnet by the outside of the bit to collect the metal chips, But what happens when the bit goes through and the chips fall into the lifter. Now what to I do?
I did do a 8N that had the holes already drilled and that worked great!
