39 9-N price?
old-9
I am dealing with a friend on some equipment and / or a 39'. The tractor is very orginal, Sn# 68XX , 32 inch rear tires, (miss matched ,one goodyear one firestone) , two rib fenders. Tractor starts very good and runs / drives great. Original tail light and headlights (C M hall) . Bran new front tires ,firestone. Large generator. Paint very good, new clutch, brakes new,new rear bearings, seals, front pivot bushing replaced.
Any way looking for an average fair price to start with. Thank you, joe
Like Del says, post some pictures. I have 4 39s. Worth more to a collector than to someone looking for a worker. CM Halls and double rib fenders are a plus. Does it have smooth axles? Does it have the snap in battery lid? Any hint of cracks on the left side of the block? Be glad to look at picture for you.
Yes two smooth axles and original snap in battery door. very original even has the non spring linch pin on 3 point. Went through everything a few years ago ,2012, been a trailor queen ever since. She does mark her spot some. joe
There are many other original early 9N items one must look at. I recently worked a MECUM auction near me and the collector had over 100 tractors. One was s/n 9N315, with aluminum hood BUT so many other parts were not original early 39. It sold for $35,000...
early 1939 Ford-Ferguson Items (not complete) but a start...
Aluminum horizontal bar grille
Small 'A' generator with rectangular voltage regulator behind dash
9 x 32 closed bar center rear tires
4 x 19 single rib front tires
double ribbed fenders -rivets may vary
smooth rear axle hubs
30/30 induction amp gauge (first 4000 models used a 20/20 amp gauge)
0-50 oil pressure gauge
Ignition 'ON' lamp left lower dash
starter button on dash
key switch on right dash
trans oil dipstick on top shifter cover
aluminum steering box
snap-in battery access door
Large non-pressurized radiator with chrome STANT cap
4-blade pusher fan
brake pedals interchangeable -both on left side
muffler shield
...to name but a few
so you just can't ask what the value is of a 39 9N, see? Many, many pictures will help us identify it better
Tim
