TJ in KY
I am having trouble with a 52 8n side mount original 6 volt system. I have been using the tractor with a finish mower to mow about 1.5 acres with no problem. The last time I cut it seemed like it cut out or sputter, but kept running. It was a little hotter ambient temp, in the 90’s when it sputtered slightly.
But now I am using a 5 foot rotary cutter on 5 acres of heavy weeds, so much so that I only take a half of a cut where it is heavy. Also the weather is in the lower 90 degrees while I am doing this. I can go about 6 rounds around the field and it will start cutting out, I thought it was fuel related so I checked the flow and the screens and they were all ok. I went out to cut again and same thing 6 rounds and sputtering under load and cutting out. Still seemed like fuel so I pulled my carb off a 1950 that has been running good and put it on it. I had a set of new plugs so I swapped them out, the old ones were ok, brown at insulator maybe running a little rich but not wet.
went out again and the same thing 6 rounds and sputtering and cutting out. This time totally died and would not restart, so I waited (of course I was in the field farthest point from the house) and let it cool down some and got it restarted (it ran but still sputtered under load) and headed for the house, there is a long hill back to the house and it started sputtering again and I almost did not make it.
So now I am thinking electrical. I had a coil off of the 1950 I am restoring, the only reason I changed it out was I did not want a scratched up coil on my freshly painted tractor. So I know it is good, used it on the 1950 tractor for about 8 hours before I took it off to paint that tractor. Put “new” coil on and the same thing, sputtering and cutting out after 6 or so rounds. Now I am thinking condenser, I had one laying around so I swapped it out and now no spark. Put the old one back in and still no spark.
I did a little checking and I have 6 volts at the coil (from switch) and out , to points, at the insulator on the side of distributor, and at the points. Still no spark. I even hotwired it still no spark.
I have cranked it so much I thought battery might be low (and my patients running thin) so I thought I would quit and put the charger on the battery overnight and look at it again in the morning.
The tractor does not seem to be overheating, no steam out of radiator, I have a screen over grill and I keep it cleaned off. I have no temp gauge.
Other work I have done on it recently:
New wiring harness. I did that while I had the tractor split to fix a loose oil pickup tube.But it has been running ok all spring, mowed with finish mower 4 times.
I have adjusted the linkage to the governor, I know the governor is in need of repair but it is tolerable, I am waiting on parts for governor (I don’t think this is related to the sputtering) The governor on the tractor is for one without a proof meter but I have a correct spare with proof meter connection.(waiting for parts)
Any suggestions would be greatly appreciated.
