8n top cover
swpaguy
So I forget where the shorter bolts go. I took them out and placed them in a box in order but I dropped the box and can't remember.
Swpaguy,The 7 shortest bolts 7/16"-14 x 1.50" go in the front and around each side,the 3, 7/16"-14 x 2.50",in the rear and the 4 7/16"-14 x 3.62" go in the back on each side by the lift shaft.
when dropped into a hole they should have about an inch sticking above the casting.
Zane
Zane,
Hope MRS is dooing good.
Have you ever "popped the head" on a 9N?
I am about to pop the head of a 10 hsp. compressor. Hopefully I will not need a gasket.
Gots to check on the valve plate.
Than ks in advance.
John,PA
