1951 distributor removal
sanway
New User
I have removed the bolt that locks down the distributor, the primary wire, dist. cap, etc. The distributor will not lift out.
Any ideas what could be binding it?
Spray the shaft with a good penetrating oil (not WD 40) let it sit for a while. Tap it gently with a hammer handle. You might need to do that a few times.
75 Tips
Corrosion! I saw a man lift the entire front of a Corvette with a fork lift chained around the distributor, trying to get it out!
Didn't move!
