9n ford cast aluminum dash
The 1941 model had 3 different dashes, the aluminum, the cast steel, and the stamped 2 piece steel. So depending on your serial # you could have one of the three.
Kirk
You have too many digits in your serial number. There is a list of serial number to the right under research and info.
You have too many numbers. serial numbers for the 1941 were 45976 to 88887. Please check your numbers again
The serial #'s you posted this time would be a one piece cast iron dash. Parts get switched around quite a bit on these old ford tractors.
Easiest way to tell is just grab a magnet and see if it sticks to the dash. It won't stick to the early aluminum dash.
What parts do I need to replace it with I can't seem to find a cast iron 1 piece anywhere and thanks Kirk for the information very helpful
Unless you are showing the tractor either the aluminum, cast or stamped steel dash would be correct for the '41. Even at a show most people won't know the difference. The cast iron dash change was made around serial number 60,000 and the change to the 2 piece dash was made at 80,799. The 2 piece dash was used from late '41 up until 47 so may be the easiest to obtain. You will not find another cast iron dash unless some one is selling one off a '41.
According to my data your tractor would have be made about the 3 week in may 1941.
Kirk
