Howard rotovator
$200/$300 in my area. Old style was offset. Howard did make a later model non offset and standard 3pt hitch. Seem nobody wants the old style cause they were a pain to hook up. If you buy one make sure you get all the parts and pieces for it.
Kirk
are you going to put the rotovator on a 2n, 8n, 9n tractor,
note to file, your tractor must have the reduction gear set for the tiller to work properly,
the standard gears are just too fast for the tiller to work properly,
but I guess you know that,
If it doesn't have a pto drive shaft than you are going to have some work ahead of you. Old style offset bolted right up the the 4 holes on the tractor and used a coupler to connect the pto shaft ( 1 1/8") to the drive on the tiller.
Kirk
