3 point hydraulics
Rayhill
New User
I have a 48 to 50 8n. I replaced the ram and cylinder for the 3 point hydraulics. Had the hydraulic pump rebuilt. When I went to use it, the 3point held a box scraper up for about a half hour. When I lowered the scraper, it blew the gasket out on the right front bottom cover. What would cause all that pressure and how can I fix it? Thanks Ray
Ray,Where a bouts are you at? I know a Ray Hill. Use a good quality gasket and don;t use any silicone gasket sealer on it,silicone lets the gasket slide and blow out under pressure.If you need a sealer to hold the gasket in place while installing the pump or top cover.Use a little HiTac sparingly and that will hold the gasket in place.
(quoted from post at 21:05:46 06/10/16)
(quoted from post at 17:17:30 06/10/16) see my response on other board where you also asked.
What's the other board? I would like to see your answer.
remove the *
http://www.nt*ractorc*lub.com/forums/nboard/messages/233083.html
(quoted from post at 18:34:08 06/10/16)
remove the *
Thank You
I am gonna assume you mean the pump gasket.
In about about 6 places around the pump base between the bolt holes but none near the oil feed oil I apply 3M 8001 weather strip gasket cement on the pump body. Apply the gasket then remove it for a few min. for the glue to take a set then stick the gasket to the pump, the gasket will not go anywhere and stay put while you fight the pump back into place...
I hope you know the top cover stays put no need to remove it to R&R the pump...
