Fast revving engine "fixed"
Finally, have looking for solution to this for a while
Found the fix on the other board, when I had the governor apart I
Reset shims to .230 per fo-4 ,well I took it apart again and reset to old shims of .255 and tada! And now I've got linear throttle action again!
I would like to thank everyone that gave me input to my problem
I appreciate all you guys ,and thought I would give you an update
I never would have guessed that .025 would make such a difference
Thank you all again!
(quoted from post at 04:21:29 06/10/16) Finally, have looking for solution to this for a while
Thanks...it's nice to hear about fixes. They are good things to keep filed away in your brain should you wind up with the same problem down the road. :wink:
