Jim in michigan
I am converting from an older engine with from mount dist to a
newer wie side, new one didn't come with a governor so I'm using
the one from original engine, issue I'd this. Original engine had
an oil return line out the bottom of the filter and into the
block, new one used one going into the governor! Where would I
hook up the oil return line on this newer engine? Or do I just do
away with the filter? Loop it to a T where the oil comes out and goes to the gauge? Or am I up the creek? Thanks
