8N misfiring under load???
1952 8N has been running great this year, but suddenly started coughing under load when bushhogging uphill. Cleaned out the carb, clean gas and good fuel flow, new plugs, all leads are tight, good battery.....so what now?? Your ideas are very welcome....thank you.
David,The next step would be check point gap and condition replace points if they are burnt or pitted or worn out rubbing block with quality,Points:NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)Condensor:NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
