Posting for a friend-8N, serial no.8n456706. Lost oil press when he stalled it while brush hog running and he accidently backed into water at edge of pond and tractor stalled. I don't believe he had overrunning clutch on hog. When he restarted it, had no oil press on gauge on dash. I loaned him master oil press gauge from our garage and he has no oil pressure cranking. From what I read on other sites, you can prime pump, thru pressure relief valve fitting on engine front cover, he said he tried that with 10w30 oil and no luck. When cover removed from oil filter had only about three inches of oil in bottom, when he first checked problem. There also has been a very slight leak of oil between casing and oil pump over past couple of years that he said he saw after he parked tractor after mowing. He said oil was down about 1/2 quart after sitting idle over winter. Could stalling brush hog out cause pump to fail due to lack of over run clutch or is this just coincidence that now no oil press? What is best route to follow from here? Thx
