I recently acquired a 1949 8N, front mount distributor, 6 volt positive ground. The previous owner was chasing a miss and was unable to find it. He replaced the plugs, wires, coil, battery, points and condenser, wiring harness, cap and rotor, ground (positive) strap, ballast resistor, rebuilt carb, new fuel bowl, cleaned gas tank and replaced all fuel screens. This tractor is running a 2N setup with the single pole generator and a cutout.
The tractor does run and will pull a brush hog, just not very well. Has a miss at all RPM, sounds like a John Deere at high RPM.
I checked the spark plugs. They are gaped correctly and are a dry, grey. I do not have a compression tester but I take this to mean compression isn't the issue.
I pulled the distributor and tried to verify his work. Points were gaped correctly. The mechanical advance weights were loose (could move axially along the shaft allowing them to get cocked) so I replaced the retaining c clips (which were MIA) and greased the slides. Bushings are good. Re-greased everything and reassembled.
I tried to re-time the distributor using an ohm meter to determine when the points opened. It seems I don't have enough travel in the mechanism to set it correctly. Off by 1/16" [u:ce7e6b9dbb]Is this common with cheaper points?[/u:ce7e6b9dbb]
Another thought; the tabs that drive the distributor are worn by 1/32 or so, on each of the driving faces. [u:ce7e6b9dbb]Is this normal?[/u:ce7e6b9dbb] I believe this is part of my difficulty in setting the timing.
The springs on the mechanical weights are not the same. [u:ce7e6b9dbb]Should there be two flat springs on each weight?[/u:ce7e6b9dbb] My assumption is there should be.
[u:ce7e6b9dbb]Is it normal to have to replace the main distributor shaft?[/u:ce7e6b9dbb] The bushings, and other surfaces seem to have no appreciable wear.
What is the distributor shaft material? Bronze right? I'm hoping there isn't wear on the cam itself.
Thanks for your help.
