3 point sprayer blackrain spray nnozzle
Iam putting together a 3 point sprayer . I already have tank 25 gallon and gauge pressure reduce valve etc. all ineed is a pump . the ? Is PTO pump or 12 volt . iam also looking at the black rain boomless spray nozzle any body use this nozzle . iam only doing food plots
(quoted from post at 19:48:13 06/03/16) Iam putting together a 3 point sprayer . I already have tank 25 gallon and gauge pressure reduce valve etc. all ineed is a pump . the ? Is PTO pump or 12 volt . iam also looking at the black rain boomless spray nozzle any body use this nozzle . iam only doing food plots
I bought a 25 gallon sprayer designed to mount on a atv, 12 volt pump. Plus a boom too. I can spray about 12 feet wide. I run it on a 3 point bracket I built.
I have an 8N that I converted to 12 volt and have it wired in through a trailer plug for quick hookup. Works good. The only problem is with 25 gallons in the tank the 8N is light in the front.
Rick
Mine has a PTO pump. Sometimes I wish it were electric
so the 3pt hitch and the pump could operate independently.
Not usually a big deal, just the occasional situation.
I use the boomless sprayer on mine...works great for doing the trails. No complaints on the open areas either.
