lastcowboy32
So, I already know that the intake valve on the #2 Cylinder had its keepers fall out of the spring. I figure that it should at least have new valves and hardware. So, I took the head off to see how the pistons/sleeves look. The sleeves look smooth. The only thing that I can see are a couple of tiny pits in the #1 sleeve, but they're so far up towards the top, that I think they're above where the rings travel. I don't know how they got there, but I'm thinking that they don't affect anything. Anybody care to look at the various deposits and tell me if they tell you anything? There were massive grayish-white deposits around the valves in cylinders 3 and 4. Piston #3 had a thick layer of black crud crusted on top of it.
I thought that I detected an ever so slight hint of antifreeze around the valves on #1. I did drain the radiator before working on the tractor, and the upper radiator hose was dry, but maybe it's just a little bit that was sitting there and leaked when I removed the head. Not sure.
Head gasket looked OK. I didn't see any gaps in it.
On another note, removing the head bolts/nuts was sort of like Russian roulette. The nuts came off of some cleanly. With others, the nut had more friction than the stud in the block, and the stud came out instead. Is this common?
Some experienced (or even inexperienced ...) opinions would be welcomed. Thanks for taking a look.
Chris
Chris
