Good morning! Cleaning and rebuilding the carb on the NAA, have a question as to the choke shaft.....
The plate (for lack of a better description) on the end of the shaft that connects to the choke linkage has come loose from the shaft. The shaft is "pinched" on the end, the plate slides over the shaft end then the shaft appears to have been mushroomed to hold the linkage plate on by the manufacturer. The plate appears to have been forced off of the choke shaft.
Question is.... any suggestions on how to re "mushroom" the end of the shaft to hold the little plate back on? The shaft otherwise appears to be in good condition and usable. I don't want to replace it "just because", and don't want to smack it with a hammer to flatten the end around the plate.
Any ideas?
Marlin
Any ideas?
Marlin
