Tall steering
(quoted from post at 21:29:53 05/28/16) Big and Tall steering for 8N ,I have never seen one before.How about any one else?
Tall Steering
When I overhauled the steering on my 3000 I had a worn race on the bottom of the shaft . I grabbed a shaft from an 8n to compare the profile . I used the lathe and a die grinder to rework the 3000 shaft . They looked identical except the 8n was much shorter . I think you could use the shaft and upper housing from a hundred or thousand series for a longer set up . the bearings and shims are the same .
